May 1, 2024 at 8:27 am
Jur Bokkers
SubscriberDear,Â
I know that in User Defined Results I can add an Expression to calculate values. I want to determine the MaxPrincipal - MinPrincipal, but at distinct load steps. In total I have 5 load steps. The calculation should be MaxPrincipal(t=5) - MinPrincipal(t=3). Is this even possible? And for each single node within my Named Selection?Â
Thanks,Â
May 1, 2024 at 8:57 am
ErKo
Ansys EmployeeÂ
Hi
You should be able to use identifiers in the MaxPrincipal(t=5) and MinPrincipal(t=3) results, say called maxt5 and mint3 respectively, and then use those (identifiers) in a user defined result expr:Â
maxt5 – mint3All the best
Erik
- The topic ‘Equation in UDR for results at distinct load steps.’ is closed to new replies.
1305
