How to set the self-active airfoil by Ansys fluent?
    • idenyu8701
      Hi I want to simulate the self-active airfoil.
      But I'm not sure which model or function should I use for it.
      The 60mm long's line on the picture is the flap that I want it to be self-active.
      Thank you for any suggestions!
      Self active? Do you want it to move?
      • idenyu8701
        Hi Rob thank you for reply.
        Yes,I want to let the flap be self-active with  velocity of the air.
      OK, that may be a little more difficult. Read up on the moving deforming mesh before you spend too much time on the geometry. You may find you need to make some adjustments based on the solver approach.
      • idenyu8701
        Ok! Thank you for your replying.????
  • The topic ‘How to set the self-active airfoil by Ansys fluent?’ is closed to new replies.
