Ansys Learning Forum Forums Installation and Licensing Ansys Products Import CAD with solid and fluid body to Rocky? Reply To: Import CAD with solid and fluid body to Rocky?
Assuming all of the tutorials were pushed over to Learning/Documentation the way Rocky uses geometry will be covered. Now, as Rocky uses the Fluent geometry it may be easier to update into Fluent and then run coupling outside of WB. Given the compute effort to run the coupled models how much effort is it to re-read the altered Fluent case into Rocky each time?Â
