Ansys Learning Forum Forums Discuss Simulation General Mechanical (Rolling) Sheet thickness after rolling doesn’t match the roller’s gap Reply To: (Rolling) Sheet thickness after rolling doesn’t match the roller’s gap
sgkcompany
Thank you for helping.
What do you mean ''try defining two contacts on the wheel and plate with the same contact/target side selectons'', you mean I can have a plane have both contact and target side?
Roll to roll use ''gauss point'' or ''normal from contact''? But normal lagrange can't use gauss point. Can you give me more info about it.
