Ansys Learning Forum Forums Discuss Simulation General Mechanical Moment Reaction is large when large deflection is turned on Reply To: Moment Reaction is large when large deflection is turned on
peteroznewman
Hi Adeleine,
When bodies have a Bonded Contact, the Moment Reaction at the Bonded Contact comes out at the expected value. I modelled a 100 mm horizontal beam with a 10 N vertical force and get the expected 1000 N.mm Moment on the Bonded Contact Region.
It looks like the bodies in your model are connected using Shared Topology. When you do this, the Moment Reaction comes out at zero.
