Ansys Learning Forum Forums Discuss Simulation Fluids Wall heat flux from constant wall temperature boundary condition? Reply To: Wall heat flux from constant wall temperature boundary condition?
Manish Patel
Reports>Fluxes gives total heat transfer rate (W). Which I divided by the area and I found that it is same value as reported by surface integral>Area averaged>Total Heat Flux. So, it's correct method right? Just want to confirm.Â
