TAGGED: #fluent-#cfd-#ansys, ansys-cfd, fluent, mesh, technical, technical-support
April 26, 2024 at 5:09 am
Gregory Harrington
SubscriberI have a Workbench project with just 2 Nodes. One is a geometry node where I import either a .scdoc file or .dsco file. The other node is a Fluent Watertight meshing node.
I am able to import the geometry and create a suitable mesh, but once I save the project a copy of the geometry is placed in the .../dp0/Geom-1.adgb file.
This isn't an issue if I no longer need to make changes to the mesh but if I have to go back to the watertight geometry node and import the mesh again then I get a CAD import error.Â
I am assuming it is because of the .agdb file type that my geometry was created in.
How do I change a setting so that my geometry file stays either a .scdoc file or .dsco file and isn't converted to a .agdb file?
April 26, 2024 at 7:20 am
Keyur Kanade
Ansys EmployeeWhat version you are using? Please use latest 2024R1.Â
Please go through help manual for more detailsÂ
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
April 26, 2024 at 2:06 pm
Gregory Harrington
SubscriberMy company doesnt have 2024, I need another solution until they get 2024
April 26, 2024 at 3:39 pm
Keyur Kanade
Ansys EmployeeYou can use standalone Fluent Meshing instead of WB.Â
Keyur
April 26, 2024 at 4:05 pm
Gregory Harrington
SubscriberIf i use standalone fluent meshing then when I make a change to my mesh I have to re-do all the setup every time i make a mesh change
April 26, 2024 at 4:19 pm
Keyur Kanade
Ansys EmployeeIf boundary zone names are same then you need not redo set up.
Keyur
April 26, 2024 at 4:23 pm
Gregory Harrington
SubscriberCan you help me with the workflow? I am a new Fluent user. What would the workflow be?
- Create mesh in Watertight mesher -> Save case file.
- Open Solver -> Load Solver case file that has previously defined setup with boundary conditions, reports, scenes etc
- Import watertight mesher case file?
April 29, 2024 at 4:15 am
Keyur Kanade
Ansys EmployeeYou can use Replace Mesh option.Â
Keyur
- The topic ‘Workbench geometry converted to .agdb. CAD import error in meshing now’ is closed to new replies.
6219
