Ansys Learning Forum Forums Discuss Simulation Fluids Chemkin Parallel hangs on 2024R1 Reply To: Chemkin Parallel hangs on 2024R1
Mike H.
Thank you again Judy. Quick question: how do I run a single chemkin case in parallel in the GUI?
I only see this option under preferences: "Number of Parameter Study Runs to Run in Parallel."
Are any of the Chemkin Sample files set up to run a reactor across multiple cores?
Thanks! -Mike
