April 25, 2024 at 7:06 am
April 25, 2024 at 2:51 pm
Guilin Sun
Ansys Employee这可能是系统显示出问题了,或者是使用C++的Klayout出问题了,参见
std::bad_allocis the type of the object thrown as exceptions by the allocation functions to report failure to allocate storage.Lumerical导出GDS的脚本你应该在使用,除此之外没有其它的。
建议重新启动计算机试一下。也有可能是Klayout不能处理太大文件?
- The topic ‘fdtd导出gds问题’ is closed to new replies.
