Hashin failure criterion
    • Ken Ng
      Hi
      I am new to ANSYS and seeking guidance on how to incorporate the Hashin failure criterion into my model. Specifically, I would like to know where to place the command (in the geometry or material section) and the correct syntax to use. I have looked through the ANSYS guide, but I'm still confused about the necessary steps to input the Hashin failure criterion. Could someone kindly provide a simple code example? Additionally, I would greatly appreciate any recommendations for finding example videos or files demonstrating the implementation of the Hashin failure criterion in ANSYS.
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v241/en/ans_mat/mat_damageall.html
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v241/en/ans_mat/elemmatstrenlimits.html
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v241/en/ans_cmd/Hlp_C_TB.html
    • Aurojyoti Prusty
      Hi Ken,
      You can refer to the below link for the commands for Hasin failure criterion.
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v241/en/ans_thry/thy_str4.html%23thryhashinfailure
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v241/en/ans_cmd/Hlp_C_FCTYP.html?q=hashin
      Hope this helps,
      Thanks
      • Ken Ng
        Thank you for the information, should I insert the command in the contacts, the geometry or the solution?
      • Ken Ng
        Hi Aurojyoti,
        Thank you for the information, I tried to put the command inside the geometry but it gave me the error:
         TB,FCLI,,,1 has already been defined.  Please delete existing table to  overwrite.
        Here is where the commands are inserted and both the content of two APDL are the same
        FCTYP, DELE, EMAX, SMAX, TWSI, TWSR
        FCTYP, ADD, HFIB
        TB,FCLI,1,,16,1,,108000000,29800000,2300000,5500000,,,7800000,7800000
        TB,DMGI,1,,,2,,1.6,60,0.06,0.2
        These are the material properties I got:
        Failure criteria:
        Parallel tension = 108 MPa
        Parallel compression = 29.8 MPa
        Matrix tension = 2.3 MPa
        Matrix compression = 5.5 MPa
        Longitudinal shear = 7.8 MPa
        Transverse shear  = 7.8 MPa
        Fracture energy
        Longitudinal tension = 1.6 N/mm
        Longitudinal compression = 60 N/mm
        Transverse tension = 0.06 N/mm
        Transverse compression = 0.2 N/mm
        I wonder what mistake I had made that cause the error?
  • The topic ‘Hashin failure criterion’ is closed to new replies.
