fixing the contact angle distribution on surface during a transient simulation
    • Amir
      hi,
      I have a distribution of contact angle (CA) over a solid wall, can I import that using import tab>>interpolation like a intial condition? like this can be done for fluid variables on even different grid size (export>>write the variable on case file then read that on the other case file)
      and is it possible to enforce to keep this CA distribution on the surface all over the transient simulation? of so how? using expressions or UDF macros?
      thanks,
      Amir
      Maybe. With difficulty. Possibly the latter.
  • The topic ‘fixing the contact angle distribution on surface during a transient simulation’ is closed to new replies.
