Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Damping in Response Spectrum Analysis › Reply To: Damping in Response Spectrum Analysis
April 24, 2024 at 3:23 pm
Chandra Sekaran
- Â
You will need to use APDL commands to input multiple curves with different damping ratios and to specify the damping ratio for each mode
The spec I am using provides SRS curves for many damping values. How would I choose which to use?
You should input all the spectral curves along with their damping ratio values using SV,damp,sv1,sv2,... Refer to FREQ and SV commands to understand the format.
I am performing a response spectrum analysis on a system with many modes, each with it's own damping ratio.Â
You can use MDAMP command to input the damping of each natural frequency
