Ansys Learning Forum Forums Discuss Simulation Fluids ERROR IN CREATING REGIONS IN WATERTIGHT GEOMETRY ANSYS FLUENT WITH MESHING Reply To: ERROR IN CREATING REGIONS IN WATERTIGHT GEOMETRY ANSYS FLUENT WITH MESHING
Can you check for small surfaces around the surface joints? Or check your local sizing - you shouldn't have so much mesh clustering around the diameter changes.Â
