April 24, 2024 at 6:00 am
yu272
SubscriberHello,
I am simulating a solid where the material property is defined via APDL command (select solid - insert command - use TB to define material constants, where the default material selected is structural steel). Therefore, the material behavior is completely overwritten by the material model and parameters I input. In this case, how do I add/modify more physical properties such as density?
Sincerely,
Eric
April 24, 2024 at 6:56 am
ErKo
Ansys EmployeeHi
See the MP command in the help manual.
Also here is a discussion similar to yours:
/forum/forums/topic/workbench-mechanical/
All the best
Erik
April 24, 2024 at 9:58 pm
yu272
SubscriberThanks Erik!
- The topic ‘Physical properties of material defined via APDL command’ is closed to new replies.
1305
