April 23, 2024 at 3:11 pm
Tim LS
SubscriberHello!Â
I am just wondering if it is possible to uninstall modules of Ansys that I am not using.
April 23, 2024 at 3:36 pm
Tim LS
SubscriberAlso, which workloads for visual studio 2022 is necessary to compile UDFs?Â
April 23, 2024 at 4:11 pm
Forum ModeratorNot with Student as far as I know. The licenced version allows some modules to be uninstalled.Â
If you click "Use built in compiler" there's no need to install Visual Studio; after many years of asking for it a CLANG compiler was built into the code. I'm not sure which version we're currently supporting, but it'll be covered in some of the "Supported Platform" documents in ansys.com and then Support.Â
April 23, 2024 at 5:41 pm
Tim LS
SubscriberWhen I try to compile the UDF with the "Use Built-In Compiler" ticked, I get the error following error message:Â
Copyright 1987-2024 ANSYS, Inc. All Rights Reserved.Compiler and linker: Clang (builtin)Â"scons: warning: No version of Visual Studio compiler found - C/C++ compilers most likely not set correctlyFile "M:\Documents\Fluent\FlotationColumn_files\dp0\FFF\Fluent\libudf\win64\3ddp_node\SConstruct", line 20, inCompiler path: "C:\PROGRA~1\ANSYSI~1\v241\fluent"\ntbin\clang\bin\clang-clLinker  path: "C:\PROGRA~1\ANSYSI~1\v241\fluent"\ntbin\clang\bin\lld-linkÂscons: warning: No version of Visual Studio compiler found - C/C++ compilers most likely not set correctlyFile "M:\Documents\Fluent\FlotationColumn_files\dp0\FFF\Fluent\libudf\win64\3ddp_node\SConstruct", line 156, inC sources: ['FlotationKinetics.c']This program is blocked by group policy. For more information, contact your system administrator.scons: *** [FlotationKinetics] Error 1"ÂGot any idea of what might be wrong? -
April 24, 2024 at 12:37 pm
Forum ModeratorTry moving the work to the local machine, but also see if you can compile the UDF from Fluent standalone. There's also the last part of the error re "group policy" so please check with IT if standalone fail too.Â
- The topic ‘Limited storage’ is closed to new replies.
4612
1515
1386
1209
