Ansys Learning Forum › Forums › Discuss Simulation › Photonics › “Unable to construct planar solid from source data” error › Reply To: “Unable to construct planar solid from source data” error
April 22, 2024 at 6:58 pm
Guilin Sun
This is an interesting issue. It seems you used the "Blender" software to create this image. I am not sure if it has any difference in data format from Solidworks. You may try the following:
1: simulate each of the import objects and see if meshing is correct.
2: if the meshing is correct, please change the default mesh order for the "blobs" and check if meshing is ok.
You may try Solidwork if it fails again.
