friction coefficient value depending on two variable parameters
    • user deleted
      I want to set the friction coefficient from two parameters.
      Please clarify - How does interpolation occur?
      linear law?
    • Aniket Chavan
      can you please explain your query in more detail?
      -Aniket
      Forum Rules & Guidelines
    • ashish.khemka
      Please search the internet for the following article titled and see if it helps:
      'Slip Slidin’ Away! Modifying Friction Coefficients During a Mechanical Simulation'
      Ashish Khemka
  • The topic ‘friction coefficient value depending on two variable parameters’ is closed to new replies.
