Ansys Learning Forum Forums Discuss Simulation General Mechanical Is node order in the stiffness matrix different from the node order in solution? Reply To: Is node order in the stiffness matrix different from the node order in solution?
dhjang4522
Hi mike
Do you mean that the node numbers seen in Workbench (Node ID) differ from those in the exported stiffness matrix?
