Lito
@Jason Bonacum,
(1) Is the license manager configured for license sharing?
>>https://optics.ansys.com/hc/en-us/articles/4660658639251-Ansys-license-manager-configuration-for-shared-license-access
(2) Can you check if the license manager shows the Lumerical licenses on the server?
>>https://optics.ansys.com/hc/en-us/articles/5770622400659-How-to-check-license-status-and-availability#toc_3
(3) Try to configure Lumerical using the Optics Launcher > Licenses configuration utility. Do Not Use the Ansys licensing client settings.
Make sure that the Port (Default: 1055) is set to the one used in the license file on the License Manager on your server (step 1 above).
>>https://optics.ansys.com/hc/en-us/articles/360026079294-Lumerical-license-configuration-with-the-Ansys-Optics-Launcher
(4) The Launcher license configuration should indicate "Standard" in the "Domain" field as shown below.
Hope this helps. Let me know if you have any questions.Â
