Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Insert Python Code object through APDL command sheet for batch automation › Reply To: Insert Python Code object through APDL command sheet for batch automation
April 17, 2024 at 7:54 am
thermalsr71
Alright, thanks. I'll check the release notes. Alternatively, is there a way of exporting temperature result data into files using APDL commands?
