Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Error in Ansys linux based server simulation › Reply To: Error in Ansys linux based server simulation
April 16, 2024 at 7:05 pm
Thank you for the response. I have renamed the folders. But, it is still showing the same error. Log of same is as below.
Event log opened 4/16/2024 2:59:24 PM EST
Product version: 2023 R2
Build version: 23.2.0.0
{4/16/2024 2:59:41 PM} [ProjectReplaced:Project] A new project has been created.
{4/16/2024 3:00:09 PM} [ProjectReplaced:Project] The project has been opened from /home/pateh123/harsh_simulation/server_analysis/server_run.wbpj.
{4/16/2024 3:00:45 PM} [BatchModeApplicationWarning:MechanicalEditor] For Frictionless Supports applied to neighboring faces that meet at a shared edge, if the angle formed between the normals of the neighboring faces is larger than 0.01 degree, the nodes on the shared edge are subject to two separate combinations of DOF constraints, one from each Frictionless Support. The Mechanical application attempts to identify a suitable orientation to the nodal coordinate system that accommodates both frictionless supports and, if successful, constrain its axes accordingly.
{4/16/2024 3:00:45 PM} [BatchModeApplicationError:MechanicalEditor] An error occurred while starting the solver module. Please refer to the Troubleshooting section in the Ansys Mechanical User Guide for more information.
{4/16/2024 3:00:48 PM} [UpdateMessage:Project] Update of the Solution component in Seperate key with press fit_new_maetrial failed: Error updating cell Solution in system Seperate key with press fit_new_maetrial.
Ansys.Core.Commands.UserReadableFailureException: Error updating cell Solution in system Seperate key with press fit_new_maetrial.
 at Ansys.Addins.Infrastructure.CommandUtilities.CommandHelper.Execute (Ansys.Core.Commands.IFullContext context) [0x0004b] in :0Â
 at Ansys.Core.Commands.Concurrency.CommandWorkUnit.executeInContext (Ansys.Core.Commands.CommandContext subContext, Ansys.Core.Commands.Concurrency.IExecutionEngineCallback tracer) [0x000a1] in :0Â
 at Ansys.Core.Commands.Concurrency.BaseWorkUnit.doExecute (Ansys.Core.Commands.Concurrency.IExecutionEngineCallback executionEngine, Ansys.Core.Commands.CommandContext subContext) [0x0002d] in :0Â
 at Ansys.Core.Commands.Concurrency.BaseWorkUnit.Execute (Ansys.Core.Commands.Concurrency.IExecutionEngineCallback executionEngine, System.Boolean dontCatchExceptions) [0x0010f] in :0Â
--- Ansys.Core.Commands.CommandFailedException: Error updating cell Solution in system Seperate key with press fit_new_maetrial.
CommandName: Mechanical.UpdateSolution(Container="Solution", RemainingDownstreamContainers=["Results"], UpdateOptions=Set(DpUpdateType=None, HeldLicenseId=None, LicenseStatsId="ead2577022e64eca9365aff88d40bbf7", DesignPointUpdateQueue=None, MaxNumberOfCores=0))
 at Ansys.Core.Commands.CommandAsyncResult.RethrowFailureException (System.Exception e) [0x0000c] in :0Â
 at Ansys.Core.Commands.CommandAsyncResult.WaitForSuspendOrComplete (System.Int32 milliSecondsTimeout, System.Boolean exitContext) [0x000dd] in :0Â
 at Ansys.ProjectSchematic.Data.ComponentTemplateEntity.Update (Ansys.Core.Commands.IFullContext context, Ansys.Core.ProgressMonitoring.IProgressMonitor progressMonitor, System.Int32 milliSecondsTimeout, Ansys.Core.DataModel.ProjectSystem.DataContainerReference container, System.String dataGroup, Ansys.ProjectSchematic.Update.UpdateOptions updateOptions, System.Collections.Generic.IEnumerable
1[T] downstream, System.Collections.Generic.IEnumerable1[T] allRemaining) [0x000cb] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0Â Â at Ansys.ProjectSchematic.Update.UpdateTask.Update (Ansys.Core.Commands.IFullContext context, Ansys.Core.ProgressMonitoring.IProgressMonitor progressMonitor, System.Int32 milliSecondsTimeout, Ansys.ProjectSchematic.Update.UpdateOptions updateOptions, System.Collections.Generic.IEnumerable
1[T] downstream, System.Collections.Generic.IEnumerable1[T] allRemaining) [0x0003d] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0Â Â at Ansys.ProjectSchematic.Update.ComponentUpdatePlugin.updateComponent (Ansys.ProjectSchematic.Update.IContextForUpdatePlugin callbacks, Ansys.ProjectSchematic.Update.UpdateTask task, System.String trackToken, Ansys.Core.ProgressMonitoring.IProgressMonitor progressMonitor, System.Int32 milliSecondsTimeout, Ansys.ProjectSchematic.Update.TaskHolder remainingTasksInThisDp, System.Collections.Generic.List
1[T] dependentTasks) [0x00130] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0 at Ansys.ProjectSchematic.Update.ComponentUpdatePlugin+<>c__DisplayClass0_0.b__0 () [0x00000] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0
at Ansys.ProjectSchematic.Update.ExecuteWithErrorBehaviour.Execute (Ansys.ProjectSchematic.Update.IContextForUpdatePlugin callbacks, Ansys.ProjectSchematic.UpdateErrorBehavior behavior, System.Action op, Ansys.ProjectSchematic.Update.UpdateTask forTask, System.Action opUponError) [0x0007e] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0
{4/16/2024 3:00:49 PM} [Ansys.Core.Commands.CommandFailedException:Message] Update failed for the Solution component in Seperate key with press fit_new_maetrial. Error updating cell Solution in system Seperate key with press fit_new_maetrial.
at Ansys.ProjectSchematic.Data.ComponentTemplateEntity.Update (Ansys.Core.Commands.IFullContext context, Ansys.Core.ProgressMonitoring.IProgressMonitor progressMonitor, System.Int32 milliSecondsTimeout, Ansys.Core.DataModel.ProjectSystem.DataContainerReference container, System.String dataGroup, Ansys.ProjectSchematic.Update.UpdateOptions updateOptions, System.Collections.Generic.IEnumerable1[T] downstream, System.Collections.Generic.IEnumerable
1[T] allRemaining) [0x000cb] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0 at Ansys.ProjectSchematic.Update.UpdateTask.Update (Ansys.Core.Commands.IFullContext context, Ansys.Core.ProgressMonitoring.IProgressMonitor progressMonitor, System.Int32 milliSecondsTimeout, Ansys.ProjectSchematic.Update.UpdateOptions updateOptions, System.Collections.Generic.IEnumerable1[T] downstream, System.Collections.Generic.IEnumerable
1[T] allRemaining) [0x0003d] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0 at Ansys.ProjectSchematic.Update.ComponentUpdatePlugin.updateComponent (Ansys.ProjectSchematic.Update.IContextForUpdatePlugin callbacks, Ansys.ProjectSchematic.Update.UpdateTask task, System.String trackToken, Ansys.Core.ProgressMonitoring.IProgressMonitor progressMonitor, System.Int32 milliSecondsTimeout, Ansys.ProjectSchematic.Update.TaskHolder remainingTasksInThisDp, System.Collections.Generic.List1[T] dependentTasks) [0x00130] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0Â
 at Ansys.ProjectSchematic.Update.ComponentUpdatePlugin+<>c__DisplayClass0_0.b__0 () [0x00000] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0Â
 at Ansys.ProjectSchematic.Update.ExecuteWithErrorBehaviour.Execute (Ansys.ProjectSchematic.Update.IContextForUpdatePlugin callbacks, Ansys.ProjectSchematic.UpdateErrorBehavior behavior, System.Action op, Ansys.ProjectSchematic.Update.UpdateTask forTask, System.Action opUponError) [0x0007e] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0Â
--- Ansys.Core.Commands.UserReadableFailureException: Update failed for the Solution component in Seperate key with press fit_new_maetrial. Error updating cell Solution in system Seperate key with press fit_new_maetrial.
 at Ansys.ProjectSchematic.Update.UpdateImpl.throwErrorIfSomethingFailed () [0x0011f] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0Â
 at Ansys.ProjectSchematic.Update.UpdateImpl+d__73.MoveNext () [0x00bc1] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0Â
 at Ansys.ProjectSchematic.Update.UpdateCommandProcess+d__5.MoveNext () [0x00071] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0Â
 at Ansys.Core.Commands.Concurrency.SuspendableCommandWorkUnit.executeInContext (Ansys.Core.Commands.CommandContext subContext, Ansys.Core.Commands.Concurrency.IExecutionEngineCallback tracer) [0x00142] in :0Â
--- Ansys.Core.Commands.CommandFailedException: Update failed for the Solution component in Seperate key with press fit_new_maetrial. Error updating cell Solution in system Seperate key with press fit_new_maetrial.
CommandName: UpdateSystem(System="/Schematic/System:SYS", AllDependencies=True)
 at Ansys.Core.Commands.CommandAsyncResult.WaitForSuspendOrComplete (Ansys.Core.Commands.CommandAsyncResult+ISuspendResumeCommands suspendResumeHandler, System.Int32 milliSecondsTimeout, System.Boolean exitContext) [0x00007] in :0Â
 at Ansys.ProjectSchematic.GuiOperations.AbstractUpdateSystemGui.Invoke (Ansys.UI.Abstract.IUserInteractor context) [0x000dd] in <03d1ae9d617b42e4aa35b2ce459f3af5>:0Â
 at Ansys.UI.Abstract.ProductionUserInvokedOperation
1[T].Invoke (Ansys.UI.GuiOperationContext context) [0x0000c] in :0 at Ansys.UI.GuiOperationContext.Invoke (Ansys.UI.GuiOperationMetaData operationData) [0x00006] in :0
at Ansys.UI.UIManager+<>c__DisplayClass206_0.b__0 () [0x00031] in :0
at Ansys.UI.UIManager.InvokeOperationCore (System.String pseudoname, Ansys.UI.Views.View+OperationDelegate callback, System.Boolean allowOSMessages, System.Boolean coreTransaction, System.Boolean deferredRefreshOnly) [0x001a6] in :0
{4/16/2024 3:01:54 PM} [BatchModeApplicationWarning:MechanicalEditor] For Frictionless Supports applied to neighboring faces that meet at a shared edge, if the angle formed between the normals of the neighboring faces is larger than 0.01 degree, the nodes on the shared edge are subject to two separate combinations of DOF constraints, one from each Frictionless Support. The Mechanical application attempts to identify a suitable orientation to the nodal coordinate system that accommodates both frictionless supports and, if successful, constrain its axes accordingly.
{4/16/2024 3:01:54 PM} [BatchModeApplicationError:MechanicalEditor] An error occurred while starting the solver module. Please refer to the Troubleshooting section in the Ansys Mechanical User Guide for more information.
{4/16/2024 3:01:57 PM} [UpdateMessage:Project] Update of the Solution component in seperate_key_with_press fit_new_maetrial failed: Error updating cell Solution in system seperate_key_with_press fit_new_maetrial.
Ansys.Core.Commands.UserReadableFailureException: Error updating cell Solution in system seperate_key_with_press fit_new_maetrial.
--- Ansys.Core.Commands.CommandFailedException: Error updating cell Solution in system seperate_key_with_press fit_new_maetrial.
CommandName: Mechanical.UpdateSolution(Container="Solution", RemainingDownstreamContainers=["Results"], UpdateOptions=Set(DpUpdateType=None, HeldLicenseId=None, LicenseStatsId="ee9b589218fa44609599c4bb3272d9c5", DesignPointUpdateQueue=None, MaxNumberOfCores=0))
{4/16/2024 3:01:58 PM} [Ansys.Core.Commands.CommandFailedException:Message] Update failed for the Solution component in seperate_key_with_press fit_new_maetrial. Error updating cell Solution in system seperate_key_with_press fit_new_maetrial.
--- Ansys.Core.Commands.UserReadableFailureException: Update failed for the Solution component in seperate_key_with_press fit_new_maetrial. Error updating cell Solution in system seperate_key_with_press fit_new_maetrial.
--- Ansys.Core.Commands.CommandFailedException: Update failed for the Solution component in seperate_key_with_press fit_new_maetrial. Error updating cell Solution in system seperate_key_with_press fit_new_maetrial.
at Ansys.UI.Abstract.ProductionUserInvokedOperation1[T].Invoke (Ansys.UI.GuiOperationContext context) [0x0000c] in :0Â
 at Ansys.UI.GuiOperationContext.Invoke (Ansys.UI.GuiOperationMetaData operationData) [0x00006] in :0Â
 at Ansys.UI.UIManager+<>c__DisplayClass206_0.b__0 () [0x00031] in :0Â
{4/16/2024 3:03:19 PM} [BatchModeApplicationWarning:MechanicalEditor] For Frictionless Supports applied to neighboring faces that meet at a shared edge, if the angle formed between the normals of the neighboring faces is larger than 0.01 degree, the nodes on the shared edge are subject to two separate combinations of DOF constraints, one from each Frictionless Support. The Mechanical application attempts to identify a suitable orientation to the nodal coordinate system that accommodates both frictionless supports and, if successful, constrain its axes accordingly.
{4/16/2024 3:03:19 PM} [BatchModeApplicationWarning:MechanicalEditor] Not enough constraints appear to be applied to prevent rigid body motion. This may lead to solution warnings or errors. Check results carefully.
{4/16/2024 3:03:19 PM} [BatchModeApplicationError:MechanicalEditor] An error occurred while starting the solver module. Please refer to the Troubleshooting section in the Ansys Mechanical User Guide for more information.
{4/16/2024 3:03:26 PM} [UpdateMessage:Project] Update of the Solution component in full_stack failed: Error updating cell Solution in system full_stack.
Ansys.Core.Commands.UserReadableFailureException: Error updating cell Solution in system full_stack.
--- Ansys.Core.Commands.CommandFailedException: Error updating cell Solution in system full_stack.
CommandName: Mechanical.UpdateSolution(Container="Solution 2", RemainingDownstreamContainers=["Results 2"], UpdateOptions=Set(DpUpdateType=None, HeldLicenseId=None, LicenseStatsId="05ed813b0786476584303aa31a3679e6", DesignPointUpdateQueue=None, MaxNumberOfCores=0))
{4/16/2024 3:03:28 PM} [Ansys.Core.Commands.CommandFailedException:Message] Update failed for the Solution component in full_stack. Error updating cell Solution in system full_stack.
--- Ansys.Core.Commands.UserReadableFailureException: Update failed for the Solution component in full_stack. Error updating cell Solution in system full_stack.
--- Ansys.Core.Commands.CommandFailedException: Update failed for the Solution component in full_stack. Error updating cell Solution in system full_stack.
CommandName: UpdateSystem(System="/Schematic/System:SYS 2", AllDependencies=True)
 at Ansys.UI.Abstract.ProductionUserInvokedOperation`1[T].Invoke (Ansys.UI.GuiOperationContext context) [0x0000c] in :0Â
