Ansys Learning Forum Forums Discuss Simulation General Mechanical Insert Python Code object through APDL command sheet for batch automation Reply To: Insert Python Code object through APDL command sheet for batch automation
mrife
Hi thermalsr71
No, not yet.  At the current release this capability is in the 'alpha' stage.  That is still in development and not yet available.  Check the Release Notes when the new releases come out.  When it is moved to 'beta' stage it will be noted; then when generally available will be in the 'new commands' section of the release notes.
MIke
