Ansys Free Student Software
The fluent application failed to start through workbench
    • yizhang shao
      The fluuent application cannot be started through workbench but it can be started separately in win64 folder. I reinstall Ansys several times but still don't work. Every time I delete the relevant system variables. The Ansys version is 2023R1, I use Win11 system. The first time this issue started because I modify "udf.dat" .
    • SVV
      Could you please share the error messge you are getting when lauching fluent from WB. I assume the working directory and root directory mentioned in the Fluent launch panel is correct.
    • yizhang shao
      Hi V.V
      Yes this is the error message. This message need a long time to appear after I select solve buttom.
  • The topic ‘The fluent application failed to start through workbench’ is closed to new replies.
