Ansys Learning Forum Forums Discuss Simulation Fluids Non-Premixed Combustion PDF generation with 4th-order interpolation Reply To: Non-Premixed Combustion PDF generation with 4th-order interpolation
Vijay Narayan
HI Mana,
Thanks for sharing your observation.
I was able to reproduce the error when migrating from FGM Model to Non premixed model on a Tutorial example; and not while setting up the case afresh as Non premixed model.
It could be possible that the issue you are reporting is specific to your model; and as I cannot reproduce the error - I cannot give further assistance in the Forum channel.
If you could create a support ticket, I could investigate your model and get the necessary resolution.
Vijay
