Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Reflected Mesh Refinement in Watertight Workflow › Reply To: Reflected Mesh Refinement in Watertight Workflow
			April 15, 2024 at 10:00 am
	Thanks Rob, Some good points to look at and I will work through.
I am running the sims on a HPC remotely and just noticed in the transcripts I am getting turbulent viscosity ratio limit warnings. At this stage I am using kW-SST steady while figuring out this mesh strategy. I figure I'll have a look at the result files and mark the limiting cells and see what the go there is.
In the meantime two final questions:
- you mention "turning off" proximity - how do you do that in watertight workflow?
 - There may be a simple answer to this and I just missed the important episode in season 1.... is there a way I can "separate" the vertical from horizontal as you mention?
Have a great day.
