April 15, 2024 at 1:57 am
April 15, 2024 at 9:27 pm
Amrita Pati
Ansys EmployeeHi Muhammad,
In FDTD simulation, we calculate the electric field first and then the mode volume is calculated using the equation. Are you using an analysis group to calculate the mode volume? If yes, you will see that there is a DFT monitor within the group that calculate the eectric field distribution.
Amrita
- The topic ‘How to calculate the mode volume in 2D PhCs structure?’ is closed to new replies.
