LS Dyna
LS Dyna
Beam-to-Beam Contacts
    • Thomas Lowery
      I am simply looking to simulate the contact between two rings made of beam elements using the thickness of the beams as the contact "surface".
      The manual mentions beam-to-beam contact:
      *CONTACT_AUTOMATIC_GENERAL is a
      single surface contact similar to *CONTACT_AUTOMATIC_SINGLE_SURFACE
      that also includes treatment of beam-to-beam contact and in doing so,
      checks along the entire length of the beams for penetration.
      But my rings don't see each other with this turned on:
      *CONTACT_AUTOMATIC_GENERAL_ID
      $#     cid        title
               1
      $#   surfa     surfb  surfatyp  surfbtyp   saboxid   sbboxid      sapr      sbpr
               0         1         2         2         0         0         0         0
      $#      fs        fd        dc        vc       vdc    penchk        bt        dt
             0.0       0.0       0.0       0.0       0.0         0       0.01.00000E20
      $#    sfsa      sfsb      sast      sbst     sfsat     sfsbt       fsf       vsf
             1.0       1.0       0.0       0.0       1.0       1.0       1.0       1.0
    • Alex R.
      Hello Thomas,
      In a single surface contact (A_GENERAL and A_SINGLE_SURFACE) the elements should be on a surfa (slave) side of a contact. Master side (Surfb) is not applicable for single surface contact.
      In your case slave (surfa) is null. To make this contact work change SURFA with SURFB, assuming that Set PID = 2 exists.
      Please find out the article about beam-to-beam (shell_edge) contact: /knowledge/forums/topic/how-to-model-contact-between-beam-elements/
      Thank you,
      Alex
    • Thomas Lowery
      I am not have any success with this, I switched to using a mortor contact as suggested by the link.  What I expect to happen is that I have two simple rings made of beams, I fixed one under the other can turn gravity on and the top ring should fall and bounce off the fixed bottom ring.  But it seems no matter what I do they just pass thru each other.
      *CONTACT_AUTOMATIC_SINGLE_SURFACE_MORTAR_ID
      $#     cid        title
               1
               1         0         3         3         0         0         0         0
      *PART
      $#        title
      Ring 1
      $#     pid     secid       mid     eosid      hgid      grav    adpopt      tmid
               1         1         1         0         0         0         0         0
      *SECTION_BEAM_TITLE
      Ring 1
      $#   secid    elform      shrf   qr/irid       cst     scoor       nsm     naupd
               1         1       1.0         2         1       0.0       0.0         0
      $#     ts1       ts2       tt1       tt2     nsloc     ntloc
           0.226     0.226       0.0       0.0       0.0       0.0
      *PART
      $#        title
      Ring 2
               2         2         1         0         0         0         0         0
      *SECTION_BEAM_TITLE
      Ring 2
               2         1       1.0         2         1       0.0       0.0         0
             0.2       0.2       0.0       0.0       0.0       0.0
      *SET_PART_LIST
      $#     sid       da1       da2       da3       da4    solver
               1       0.0       0.0       0.0       0.0MECH
      $#    pid1      pid2      pid3      pid4      pid5      pid6      pid7      pid8
               1         2         0         0         0         0         0         0
    • Alex R.
      Hello Thomas,
      In your contact SURFATYP = 3 means a single part, PID = 1. In your case you should use SURFATYP = 2 Part set ID.
      Please try *CONTACT_AUTOMATIC_GENERAL.
      Thanks,
      Alex
  • The topic ‘Beam-to-Beam Contacts’ is closed to new replies.
