k-kl-omega post processing
    • Antoine
      Hi all,
      For my project I am ask to study the laminar-turbulent flow transition around an aerofoil (Eppler387 aerofoil). To do this I am using Fluent and the k-kl-omega transition model.
      The thing is, I don't know how to visualize the transition in post-processing...
      Can you help me on that ?
      I've looked for tutorials and stuff but could not found anything concerning the k-kl-omega..
      Thank you in advance.
      Antoine
      Have a look in the Turbulence part of the post-processing: there are likely some variable there. Using those look in the User'S Guide for the alphanumeric definitions (one of the last chapters) where all of these variables are defined.
    • Antoine
      Thank you !
      I will check that and come back to you whether it works or not
    • Antoine
      Hi rwoolhou, I have found the turbulence variables you were talking about. I've actually plotted some of them.
      Do you know which one will be the best to predict the transition ?
      I have plotted the eddy viscosity contour, the turbulent viscosity, the specific dissipation rate (omega) and the turbulent kinetic energy. All theses come from my analysis of the Eppler-387 aerofoil.
      Not sure without doing some reading (and as you're the student you can do that!). If you look at the various options I suspect you'll want some sort of ratio/relationship between turbulent/laminar viscosity or generation/dissipation rates or the like  (check the definition of Turbulent Reynolds Number (Re_y) ).
      What do Stokes & Reynolds have to say on the subject?
Viewing 4 reply threads
  • The topic ‘k-kl-omega post processing’ is closed to new replies.
