Ansys Learning Forum Forums Discuss Simulation Electronics FSS unit-cell with pin diode simulation using Floquet port Reply To: FSS unit-cell with pin diode simulation using Floquet port
Irina G.
Lumped RLC boundaries should work in Unit cell. How much difference in S-parameters (Mag and Phase) do you expect?
I would check first for Shorted / Open case as a base line.
