Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Question for RMxpert.. › Reply To: Question for RMxpert..
April 11, 2024 at 9:49 am
Hi min el,
- In the winding window for winding type select "Editor". Then Goto Machine>winding>Edit layout
Then on the popup window, you can customize the winding configuration. - Winding information can be input on the winding window. 8 is the number of strands and calculate the conductors per slot according to the number of turns. you can choose the wire diameter also which is the diameter of each strand.
- Not exactly on the outer rotor, but you can refer to the inbuilt examples that come with the installation (File>Open examples>RMxprt).Â
Also, look at the below pathÂ
Navya
