April 10, 2024 at 4:27 pm
315914335
SubscriberI have a udf that has compiled successfully under windows, but the same c file fails to compile under linux. Please tell me how to solve this problem. My windows version is 2022r1 and 2020r2, and the linux version is 2020r2. Please tell me how to successfully compile this file under linux. Or is it feasible to import the same Windows compiled file into Linux?
April 10, 2024 at 4:30 pm
Forum ModeratorWhat error are you getting? Did you check for whitespace characters?
You can't use the Win10 libudf on Linux.
April 11, 2024 at 3:37 am
315914335
SubscriberWorking...for d in lnamd64/[23]*; do \( \cd $d; \if [ -f udf_names.c ]; then \mv -f udf_names.c udf_names.cRenamed; \fi; \rm -rf *.{c,h,cpp,hpp}; \if [ -f udf_names.cRenamed ]; then \mv -f udf_names.cRenamed udf_names.c; \fi; \for f in ../../src/*.{c,h,cpp,hpp} ../../src/makefile ../../src/user.udf; do \if [ -f $f -a ! -fbasename $f]; then \echo "# linking to" $f "in" $d; \ln -s $f .; \fi; \done; \echo ""; \echo "# building library in" $d; \if [ "" = "1" ]; then \echo "# using gcc64"; \make ARCHC=gcc64 -k>makelog 2>&1; \else \if [ "" = "1" ]; then \echo "# using gcc"; \make ARCHC=gcc -k>makelog 2>&1; \else \make -k>makelog 2>&1; \fi; \fi;\cat makelog; \) \done# linking to ../../src/rate_bfer.c in lnamd64/3ddp_host# linking to ../../src/makefile in lnamd64/3ddp_host# building library in lnamd64/3ddp_hostmake[1]: Entering directory `/home/data/lv/test/density-based/rate1/lnamd64/3ddp_host' -
April 11, 2024 at 9:26 am
Forum ModeratorNothing diagnostic there, if the code has a problem I'd expect some errors.
- The topic ‘Complied UDF in linux and windows’ is closed to new replies.
- Is it able to solve turbomachinery using density-based solver in Fluent?
- Two-way FSI simulation
- Ensight Force_per_unit area_EV
- RIBBON WINDOW DISAPPEARED
- Fluent Meshing Error when .dsco not .stp
- Ansys Fluent for modelling Ocean Wave reactions to Wave Barriers
- Battery Pack cooling
- ISAT ABORT error
- UNASSIGNED INTERFACE ZONE DETECTED FOR INTERFACE…
1495
1386
1209
