Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Use only displacement(U) as a convergence criteria Structural Static APDL › Reply To: Use only displacement(U) as a convergence criteria Structural Static APDL
April 10, 2024 at 9:37 am
Aurojyoti Prusty
Why do you want only displacement convergence? By default, Ansys operates in a program-controlled mode for convergence criteria, which means the software automatically selects the appropriate convergence checks for the problem at hand. Therefore if it selects force and moment, then these criteria are more important which relates to the physics of the problem. what exactly you are tryong to analyze?
Thanks,
Aurojyoti.
