Ansys Learning Forum Forums Discuss Simulation Fluids Problems with dynamic mesh settings while mesh motion Reply To: Problems with dynamic mesh settings while mesh motion
Midjan Jusic
Hello, thank you for the answer. I tried it again. I still have problems with splitting cells above the cylinder. Collapsing below the cylinder works perfect.
If I build the model like here:
everything works. But I need the area above the cylinder to define a pressure-inlet, because I want to move the cylinder by giving pressure in the pressure-inlet.
Question 1:
Do you have any idea, why the collapsing process works but the splitting not? The cells are still stretching above the cylinder. I tried various cell heights and splitting parameters.
Question 2:
If I definied a body force with -9.81 m/s in Y direction because I have water in my model. How can I make sure, that the cylinder does not fall downwards with -9.81 m/s? I want to move the cylinder with pressure at pressure-inlet.
Thanks a lot!
