Ansys Learning Forum Forums Discuss Simulation LS Dyna Railgun Simulation – BEM fail to converge Reply To: Railgun Simulation – BEM fail to converge
Shi Hao Ng
new update: https://github.com/Ice-Citron/FEA-Physics_IA/tree/main/FP16%20archive%20-%20cords_flattened/Modified%20-%20fp16%20%2B%2075segment100mm
Update: I changed the coordinates manually, so that it fits the exemplar, as in all the nodes that are supposed to be in contact are now the very same. Yet the error still is as seen in the image below. Now assuming there is no more issue with the meshing, what can possibly be the issue with the armature not having contact with the rails? Maybe I should just try and do the conventional classic "em_contact" instead?
