Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Prevent penetration of an object to other object using contact › Reply To: Prevent penetration of an object to other object using contact
April 8, 2024 at 10:09 am
It would be better the cube and the part of the beam have the same diameter. Additionally, the surfaces which take part in the contacts(target and contact), should have a refined meshing. You could have a better insight on the penetration (except for visual) by using Contact tool in your Solution branch. In this link, you can find some tips on how to avoid penetration. I think you will find helpful!
Kind Regards,
Stella
