Ansys Learning Forum Forums Discuss Simulation General Mechanical Prevent penetration of an object to other object using contact Reply To: Prevent penetration of an object to other object using contact
kyungha.lee
Hi, Stella.
Thank you for your kind instruction on contact definition.
I have just selected Normal Lagrange and ran the simulation, however, it still penetrate the surface as shown below.
Is there any other option I should select or modify? I have attached my setting for frictionless contact.
Thank you very much in advance!
