Ansys Learning Forum Forums Discuss Simulation Fluids Change default exported variables in Fluent Reply To: Change default exported variables in Fluent
alexander.helbok
Thanks for your reply,
to specify my question a bit, after a simulation run Fluent will save some simulation parameters on a per cell basis (eg a pressure value at every node) to a .dat.h5 file. This can be opened in a post instace, where contours, isosurfaces etc can be created. I can export a data file from fluent where I can choose which quantities will be included (file -> export -> solution data...), but since Fluent automatically saves a .dat.h5 file after a succesful simulation (with a limited set of included quantities) I was wondering wether I could stop manually exporting a data file by changing fluents defaults.
Afaik, report definitions are global parameters, which are not computed on a per cell basis (or am I wrong?)
