Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Why is there no Burnout Stoichiometric Ratio? › Reply To: Why is there no Burnout Stoichiometric Ratio?
April 5, 2024 at 2:52 pm
SVV
Hi ,
The Burnout Stoichiometric Ratio and Heat of Reaction for Burnout are no longer available in the Create/Edit Materials dialog box, as these parameters are now computed from the particle surface reactions you defined in the Reactions dialog box. For more information refer to 20.7.2. Setting Discrete-Phase Physical Properties (ansys.com)
