Ansys Learning Forum Forums Installation and Licensing Ansys Products Fluent Calm Water Conditions for decay test Reply To: Fluent Calm Water Conditions for decay test
Zero flow is fine. Note, the D in CFD is Dynamics so you may find converge (residuals) to be relatively poor - also review what the residuals represent.
Have a look at the surface reports for mesh; you may not have an easy angle report but min/max may be sufficient? Unless the UDF for 6DOF can return something?Â
