Ansys Learning Forum Forums Discuss Simulation Fluids Pressure inlet condition explaination Reply To: Pressure inlet condition explaination
Essence
As far as I can see, the maximum pressure is about 7.6 MPa and not the average pressure. If you take the average, then it should be lower I assume. And one more thing, when you apply the swirl to the fluid, basically you are trying to impart the radial pressure gradient to the fluid. Therefore, this type of behaviour could be expected.
