Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Error in DEFINE_PB_BREAK_UP_RATE_FREQ UDF example from manual › Reply To: Error in DEFINE_PB_BREAK_UP_RATE_FREQ UDF example from manual
April 4, 2024 at 7:22 am
The error you're encountering (SIGSEGV) typically indicates a segmentation fault, which commonly occurs due to accessing memory that you don't have permission to access.
To debug Print out the values of epsi, alpha, and rho_d before using them in calculations to ensure they are not causing any issues.
