Ansys Learning Forum Forums Discuss Simulation General Mechanical Need help with moving heat source on uneven surface with apdl Reply To: Need help with moving heat source on uneven surface with apdl
dlooman
So the laser is just heating the tip of the tooth?  Volumetric heat generation doesn't seem like an appropriate way to model the surface heating of a laser.  If you create a very fine mesh of the tooth tip area you could select nodes on the surface based on their theta coordinate in a cylindrical system.  You could update the theta values over time:
csys,1   ! global cylindrical
nsel,s,ext  ! nodes on the surface
nsel,r,loc,x,mid_tooth,top_tooth+increment
nsel,r,loc,y,theta,theta+small_angle  ! needs to select at least two nodes for a face to be defined
sf,all,hflux,value
allsel
time,...
solve
reselect
next time
solve
soo
