Ansys Learning Forum Forums Discuss Simulation Fluids Particle count in a room Reply To: Particle count in a room
andrew o'sullivan
Hi Rob, I only plan on running the model for 10 seconds maximum as the real life cleanroom removes particles of a rate of 6000 every 10 seconds on average, What part of the model would you suggest I set the pressure outlet to?, as I tried the wall and the simulation is taking far too long. Why do you suggest I set the updates to 0.001 seconds?, below is the post processing results for a group injection with 300 parcel close to the centre of the model.
