Ansys Learning Forum Forums Discuss Simulation Photonics Lumerical HEAT Convection Boundary Condition Missing Fluid Material Properties Reply To: Lumerical HEAT Convection Boundary Condition Missing Fluid Material Properties
Amrita Pati
Hi Nicholas,
I can run the simulation example successfully as well. And I also changed the material of the film from Si to SiO2, I don't see any issue with that too. After you partition the geometry, can you see that each domain is assigned the correct material:
After you partition, you can click on "Check" to see if there are any issues with the setup:
Do you see any error messages on doing that?
Amrita
