Ansys Learning Forum Forums Discuss Simulation LS Dyna Collision study in Ansys LS Dyna Reply To: Collision study in Ansys LS Dyna
Armin
Thanks Mans.
Sure, you can increase the End Time to better observe the post-impact response. Doing so, if you faced a long solution time, look up a technique called “mass scaling” in explicit dynamics analysis that helps to reduce the computational time. You can refer to the course I shared with you earlier for a more detailed description.
