Ansys Learning Forum Forums Discuss Simulation General Mechanical Probem with modal Analysis Reply To: Probem with modal Analysis
Erik Kostson
Hi - it sounds so yes - there are some other techniques that are common and appropriate for calculating wet modes of ships (so taking into account the fluid added water effect) using panel methods - we do not have that currently.
One example of such methods can be found here
https://www.atlantis-press.com/article/22234.pdf
