Ansys Learning Forum Forums Discuss Simulation General Mechanical Slow down of a mechanical simulation after restarting Reply To: Slow down of a mechanical simulation after restarting
Lane Jancy
For instance, in the Hybrid Parallel mode of the Ansys APDL program:
If you specify 32 cores, the system may opt for 8 DMP x 4 io games SMP.
By including -nt 1 in the APDL Command Line, you have the option to disable this auto Hybrid Parallel mode.
This method, 32 DMPs will be selected when 32 cores are needed.
