Ansys Learning Forum Forums Discuss Simulation General Mechanical Analysis of Robotic Finger Reply To: Analysis of Robotic Finger
ROHITH
ill try to modify the geometry but i need to know how solve the problem with the modified geometry because i didnt understand what you meant of using revolute joint at the corners, virtual body and all if you could make one ill try to understand it and apply to all otherÂ
