Ansys Learning Forum Forums Discuss Simulation General Mechanical Non-linear calculation that fails, Deformation of a fence following an impact Reply To: Non-linear calculation that fails, Deformation of a fence following an impact
Raphaël BEVAN
Hi Armin,
Thank you again for your prompt feedback, I have applied your advice and we are still with a calculation around 48h.
We know it’s not a simple geometry but I think Ansys is able to work with more complicated models and I think we forgot something to complete our calculation.
Our fence is like that :
And we want to compare our model with real life tests we have realized. To explain quickly, we pulled on a beam (symbolized here by the cube) and measured the deformation as a function of the force applied. We want to validate a model who is giving close results to our tests.
And during our real test, it took us around 10s to remove the ties but if we make a model of 10s we have a time of resolution of 400h.
Do you think it’s possible to do it with Dynamics Explicit ? and how ? Is LS-DYNA a better solver for those long calculations (end time > 1s) but with highly nonlinear deformations ?
Thank you for your help.
Best regards
