Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Force Convergence Issue in Solder Joint Reliability Simulations › Reply To: Force Convergence Issue in Solder Joint Reliability Simulations
March 29, 2024 at 2:38 am
I don't neeed frictional contact or thermal resistance in between so I guess the share topology is fine the way I am doing. I will use N-R Force Residual plots to see what bodies in my geometry is causing force convergence issue. I will reach out with those plots once I have the data. Thank you so much for your advise.Â
